Old 12-12-2007, 06:09 PM
wavelength wavelength is offline
Default Re: Fishing for the Moesly's
Why do you want to pull the tank? Fred built them out of fiberglass and I've not heard of one failing. The only issues I have is with the fill. The fuel tank requires an 1 7/8's fill hose and the standard is 1 1/2 or 2in. I used a two inch and threaded a brass barb that is 1 7/8's OD.
Back to the tank... you have to pull the cap or cut the bulkhead in front of the cockpit, the one you can see while underway. Then pull it out into the cockpit, not fun.
70% of the earths surface is covered by water...It's going to be a very long day...Florida Marine Patrol.
