Old 12-18-2007, 11:08 PM
3rdday 3rdday is offline
Default Re: 21 Seacraft Paint and Sand
The above steps look great.
Can that stripper be used on fiberglass? It may soften it.
Before any sanding and in between sandings Always wipe down with acetone. Before initial sanding I wipe down with acetone at least 2 times sometimes 3 times. If you do not, when you sand you will rub any waxes or foreign agents into subsequent layers compromising the bond of the new.
A great newer paint to use is the 2 part interlux perfection, the results are stunning! even when brushed or rolled on with the right brush or roller.Stuff is bullet proof. Good Luck.
