Old 01-03-2008, 01:01 AM
Default Re: Installing an armstrong bracket
That should do it! One note to consider...which you may have already...You are well on top of this project. If your hardware bolts, nuts, washers are stainless I would reccomend a graphite grease to isolate them from the aluminum, can cause galvanic corrosion
This is the ONLY stuff that works!
------> CLICK HERE <-------
