Re: Floatation
I believe the CG requires enough floatation in them to float if they swamp. From what I have seen, especially in CC boats with tops, they tend to "turtle". That is roll over, and they can float a long time like that. The liner in these acts like a second boat within a boat, but given enough water and time, they probably will sink.
I have a 88 Sceptre, and had a major plumbing malfunction, and water was coming out of the drain in the cabin. I fixed the malfuction, closed the seacock, and the pumps took care of the rest. A high water alarm is a cheap item, that few use, and I highly recommend them. Knowing you have excessive water in the bilge while the problem is managable is a better plan, then dealing with it when it is out of control.
