Where did glass pull away? Where the stringers are tabbed to the hull?
Stringer
Let see if I can explain this. If you take the stringer and pinch it. It will compress. If you try torquing it left and right it will give? twist slightly. Now this does not happen through out the stringer just in certain spots. You can see the stringer glass has not pulled away from the hull. Just that the interior bond to the wood is gone (or the wood is gone). Hope this makes sense.
That is why I am wondering if a pour composite might work?
