Re: Which Side Up?
It would depend on what material you are using to bond it to the lower skin. If you are using a thin runny material scored side down will leave voids or air pockets. If you are using very thick it won't, and it will give you a smoother surface topside to work with if you are not going to re-use the top skin you pulled off. It also depends on the crown if it is a convex steep crown you may not be able to go scored side down.
