Old 01-11-2008, 04:32 PM
riprunner riprunner is offline
Default Re: 350HP crusader in a 23 inboard.......
I was hoping it would be quicker too, it's really the only negative I have with the boat. I started with a 15x17 wheel and based on suggestions here and original specs moved to a 16x17 wheel and a got the same exact numbers with a little bit more vibration. At that speed I burn about 10-10.5 GPH on the smartcraft gauge. My numbers are pretty close to everyone else with inboards that I have talked with even though I push more HP than most. I also have a very tall hard T-Top with enclosure and usually run the boat heavy on fuel so that does effect my numbers slightly.
Nexgen, do you have a t-top, bottom paint etc...? What are you doing to get those fantastic numbers?
