Old 01-14-2008, 12:33 AM
Ed Ed is offline
Default Re: Bunk or roller trailer
ABL111-
Have you tried moving your bunks in a bit? It looks like they are very far out and as a result, the hull is bottoming out on the keel rollers before it makes contact with the bunks which should center the boat. As it is setup now, teh weight is on the keel rollers...and when the hull rolls off them during unloading and loading you get the gouges.
I would try moving the main bunks in first. Then once they are in position, you adjust the existing rollers to take a little bit of weight (bunks should carry the vast majority of the weight) or you can ditch the rollers and just swap in Captain Chucks v-blocks and front bunks.
