Old 01-25-2008, 04:42 PM
Default Re: Here We Go Again
The weather gods have been good to me lately allowing for ample time to work on the boat. Things are really starting
to take shape now. I have the LP mounted and all the plumbing to the live well complete. The only things left to are to finish the wiring, rigging and then some upholstery work. I've been instructed by one of the higher up's on this site keep the pics coming!
Here are some shots of the basic layout on the boat;
Emblem and sticker are affixed to the hull! The big thru hull is the drain for the bait tank;
The bracket has a 25 inch set back
Shut off for the bait well overflow
Lid for the bait well (3/8 plexiglass)
The starboard side of the Lp has a quick release for the wash down hose;
On the port side there is another door and a end of day drain for the bait tank. After talking with bigshrimpin I
decided that I did not want to cut another hole in the side of the boat for the bait tank drain. It will drain onto
the deck and out the scuppers. I usually fish with just a few live baits for stripers so the water could not be too gross most of the time.
Some of the plumbing inside the LP
The fiberglass Leaning post has a flange that fits perfectly into the top of the bait tank
I had limited room in my rigging tube and while I was able to fit all the rigging thru the tube things were a bit cramped in there so I decided to install a pos and neg terminal on the transom so I can run smaller battery cables
to the motor thereby freeing up some space in the rigging tube.
Access door on the transom;
Theres plenty of room to walk around on this boat;
Dont mess with this fella;
