Thread: Epoxy Kick ?
Old 02-03-2008, 02:45 PM
Default Re: Epoxy Kick ?
IslandTrader,
Based on my experiences, something is wrong. That stuff should be as hard as a brick, given the time frames you laid out. What brand of epoxy are you using, and are you sure your mix ratios were correct? The pumps are not very accurate and there is a lot of waste associated with them. Next batch, don't use the pumps, just pour into small cups, making sure you get the proper ratio.
I will mix up a new batch today and give it a shot. I will only use the pumps to transfer the stuff and use the measuring cup. I will keep everyone informed.
