Thread: Epoxy Kick ?
Old 02-03-2008, 05:48 PM
bobbert bobbert is offline
Default Re: Epoxy Kick ?
Have found when using pumps, you can not make a small batch. The pumps are not full and you get inaccurate pump. usually the hardener is off.
Also have found that epoxy really slows down under 70 and with high humidity. A solution may be get some heat lamps and heat the surface. Also the comment about mixing is right on. You really have to mix that stuff good.
