Re: Thru-hull locations?
Just replaced most of mine. `89 20sf tracker hull. Bottom = bilge. 2 just above and slightly outboard. Starboard= livewell inlet. Port= livewell end of day drain. . Just above and to port was 2 3/8 O. D. livewell overflow. Weird size. Had to make a glass sleeve to make up the 3/8" Mine were all plastic. Now all bronze. The inlet hole was not properly aligned and was a challenge to straighten relative to the transom angle for proper bedding. Also had to sleeve w/ glass. Thru hull starboard side is bilge pump out. Forward fish box starboard self bailing drain. I installed a clamshell pick up for my new livewell just behind my gas tank 9" port of keel Tuff gel and 5200 to bed and help prevent galvanic corrosion.
GFs
