Old 02-15-2008, 11:01 AM
Default Re: post your livewell setup!
I put in a clamshell 5" behind the tank and 6" port of the keel to hide it a tad. Cut down the threads to 1 " , ball valve on top, and cut down Rule 800 livewell/washdown on top. You want it low to keep the pump happy. The clamshell will "ram" water through the well while runnin w/. out the pump. Those pump shafts will break so the valve is NOT an option, and fast access is a must.
GFS
