Old 03-01-2008, 10:28 AM
Default Re: Suggestions on deck replacement
Many of the guys here have redone their decks. Usually the method is different depending on if your boat is the 20’ or the 23 footer. On the 20 footer most guys raise the deck thus the method is to remove the whole thing and build up the stringers higher and then replace the entire thing. On the 23 footers most guys have just removed the top glass then removed the balsa lamination replaced the lamination and either put the old skin back or re glassed a new top skin. There are a number of forum threads and pictures showing both methods. You can also look under SeaCraft Galleries and check out your boat length for some pictures there. If I had to do it over again today I just might raise my deck on my 23 footer because of the motor’s today keep getting heavier and heavier and if my deck were lets say 3” to 4” higher than it currently is that would be a Good Thing.
BEFORE
MIDDLE
FINISHED
FellowShip
__________________________________________________ ________
Just for the Grins
