I wonder if your cuddy door is original and what its and its frame dimensions are.
Gillie, here are the measurements of original door & frame; will try to follow up with some close up photos:
Door: 19 1/8" W x 48 5/8 H. Louver section is 14 1/2 W x 33"H. Total width at OD of frame at top is approx 20 7/8".
Frame: Max cross section is 1 3/8 deep x 3/4" wide, but is milled on ID to leave a lip about 3/16" square at back edge for door to seal against. Frame across top is about 1 1/4" high, tapering to 3/4" high at ends where it mates with side frame; has same 3/16 lip as side frames. At the bottom frame begins to taper when it reaches steps that are just aft of bulkhead; tapers to ~ 1/16" wide at bottom. Denny
