Old 04-02-2008, 10:52 PM
hobson hobson is offline
Default Re: NEW Classic SeaCraft Merchandise
Hello everyone, I'm Tyler from Castaway Customs. We are Central Florida's authorized Seadek installer. So bascially I deal with anything custom since Seadek no longer does custom work. I figured I would chime in and let everyone know a little more about the products we are offering. For those not familiar with Seadek's products they make a varitey of products including helm pads, cooler pads, floor kits, undergunnel pads and coaming bolsters just to name a few. We can basically make any type of pad you need for your application. All pads are applied with a pressure sensitive adhesive so they are just peel and stick. The pads are made out of an eva foam formulated for the marine environment so it will not mildew or fade. All pads can be made in a varitey of thicknesses and colors. For example Capt Chuck's pad is 3mm mica over 3mm black. We make the pads in white, cool gray, storm gray, black, beach sand, seafoam green, carribean blue, mica, and even camo both standard camo and even a snow camo. The standard helm pads will be 13mm thick. So you can pick a bottom color which will be 10mm and the color of the logo and then a top color which will be 3mm. We also make all products in single colors, but in order to put a logo in we have to use two colors. To order a pad all you have to do is shoot me an email at tyler@castawaycustoms.com. For standard rectangle or square pads similar to Chuck's all I need is the dimensions, colors, thickness you would like, and the year of your boat. If you would like a pad that has cut outs for hinges, curves, or anything else you can either mail me a template or if you are going to the Longpoint gathering, I will have my digitizer there and can take custom templates off of any boat. I also make my way around the state so if you are in Florida I could possibly come to you to digitize a pad. Pricing will all depend upon the size and complexity of the piece. If you guys have any questions feel free to shoot me an email or you can check out www.castawaycustoms.com or www.seadek.com for more info on the products. 10% of all sales that are generated from this site will be donated back to the site and keep an eye out in the raffle for some custom pad giveaways. Thanks for your time and I look forward to meeting some of you guys in the next week, unfortunatly my boat has been put on hold due to opening this business but I can at least dream about it being finished after looking at yours.
