Old 04-04-2008, 12:58 PM
castalot castalot is offline
Default Re: I/O drive paint - protection from @!#$% barnacles
i had the same drive in ri i used interlux trilux black and only had barnacles in the stainless prop hubs none on the drive its self keep a close eye on the prop shaft seal area the duel props attack the drive in that area you can't see it unless you remove the props i installed a second mercathode thru hull system to stop the electrolysis
good luck and tight lines
