Old 04-06-2008, 09:55 AM
bobbert bobbert is offline
Default Re: Fuel gage/sender problems
Have you checked the voltage at the sender. Some times the
ignition switch develops slight corrosion in the run position
causing a drop in voltage and bad sender readings. Have found this to be a common problem.
BOB
