Re: reviving old seacraft (propeller question)
Bits . . . lose that prop. Put on a Mercury Mirage "Plus" 19p or 17P. That will fix the light bow problem. I don't know what the deal is with some of the michigan props . . . they give these seacrafts really squirrelly handling problems. I've been through this before with my boat with the same motor. I also liked the Highfive, but the cruise and top speed was not as good as the mirage plus . . . a fun prop none the less. You can find them on ebay frequently for under $200.
As far as having a level ride . . . you can try to pull of the doelfins and adjust the zinc trim tab on the lower unit. I have a very small low profile one. I honestly think the prop will go a LONG way toward fixing your problems.
