Old 04-23-2008, 06:24 PM
Default Re: Primer!!!!!!!!!!!!!!!!!!!!!!!!
Will yes it is the same primer that you get with pvc glue. I think the dykem(spelling?) is darker and might be better for the job. I have an endless supply of primer. The first side I used a rag (make sure you were gloves) The second side I rolled it on with a 6 inch mini roller and it went on much darker and much easier. I would advise taking a pencil circling the low spots and then sand the primer off. I had a little problem with bleed through on my Awlgrip 545 primer. As Strick says " Nothing a little Primer cant fix!" I just had to lay two more addition coats over it to cover.
36' Yellowfin
1972 20' seacraft 140 suzuki
