Re: Transom rebuild thread
If your doing an outer type transom rebuild, make sure to check the glass on the inside. Even in "hallowed" seacrafts, I have seen quite a few voids and dry spots on the inside. Mine had an area 12x16" on one side that was not stuck to the wood, and was not wetted out very well. The outer doesn't seem to have the same problems. If I was closing in a transom, I would probably do it from the inside, if I was just redoing a notched transom, that I think the outside would be the way to go.
