Old 05-07-2008, 11:39 PM
Mark Mark is offline
Default Re: Leak Through Fishbox Thru-Hull
I discussed your boat with Capt Chuck yesterday actually. If you are fairly confident that is the source of the water, and based on where you are located (right here in Stuart), run yourself by Wildfire Marine and have Mike fix it. He's located almost directly across the street from Crowder Rods, if you don't know where that is, ask any of the other guys there at FK and they'll give you directions. Give Mike a ring, tell him I gave you his number, and describe the problem - his number is 286-1925.
