Old 05-17-2008, 12:23 AM
3rdday 3rdday is offline
Default Re: 1996 Johnson 115 HP V4 - Low Compression one hole
It probably wont run well under a load, un-equal pressure may be put on the crank. That is a great engine, great electronics on it. Right now the issue may be rings, if you run it you may cause other problems, cylinder damage, block damage, piston, piston rod, crank, head etc. May as well replace all of the rings, while you have the block apart. have someone take a micrometer to that cylinder also.
