Thread: Wiring surprise
Old 06-01-2008, 08:58 PM
Default Re: Wiring surprise
Thanks for the feedback. Slip-bolt, huh, is that for house wiring or just a common connector for different sized wired? Is that thing between the wires a fuse? It did work fine, ESD, as you can see by the 4 blown fuses, plenty of power getting there. Just a bunch of bad grounds...I've been tracing wire and found a lot of errors but now I have everything working except the Klaxon horn. Only a pos and a neg terminal on it, but I haven't figured it out - maybe the compressor is shot. My plan is to scrap it all, and go with a Blue Sea ST Blade fuse block to tinned type 3 6 ga AWG wire w/tinned, closed heatshrink terminals, to separate pos & neg mini buses at the stern, and then to a Blue Sea acr/si like Rhody98 pictured in his Seafari wiring post. Any pics you guys might have of your distribution would be helpful as I'm still debating the final approach... Thanks again. -- McGill
