  #55
Old 06-04-2008, 05:37 PM
Default Re: 21 Hull #136...Restoration...Started
Moving along... I got the dash filled and faired out.
The Original Dash Panel looks good, so I plan on using the SS panel and insert new gauges.
Just basic work here. I did not want to fill from the back of the dash because the angle was such, that cabosil running out would be a problem.
I just laid on layer of 1708 on the back side to close off the holes. Made some plywood plugs for the front, and mixed up a bunch of epoxy and cabosil, and start laying in.
After that was dry I started using Quick Fair to get every thing smooth. Used dykem to find the low spots.
Next week on to the transom.
Original Dash Set Up
Dash Stripped.
Glass Back of dash.
Wood Plugs.
Dykem the dash.
Low spots.
Smooth Dash.
New panel Original Gauges.
Had enough
