Old 07-25-2008, 05:37 PM
BigLew BigLew is offline
Default Re: some more work, Non skid , console modification
A quick idea. (I don't like 5200. In my opinion, it is used much too often and ends up costing more time and aggravation than it's worth. But I do admit it has its place.)
Consider this. Make a base that is screwed down/permanently attached to the deck where you are going to 5200 the cooler into place. On top of that you can devise a mount or tray for the cooler. Then, the cooler can come on and off as needed or is convenient. You can design it in such a way that it will overlap the flange of the console and not limit you in pulling ot moving the console if you need to.
If you decide to change your mind/configuration later, it is only a matter of removing that base (probably a few bolts through the deck.) Just my 2¢.
Plan accordingly!
