Thread: Hydrogen Power
Old 07-29-2008, 03:26 AM
nos3665 nos3665 is offline
Default Re: Hydrogen Power
What are you going to use as a vac-pump on this 2 stroke?
Some of the older GM Fwd cars had a stand alone ele-vac pump that gave 21 lbs constant ran on 12 volts and built much like our pulse fuel pump, If you dead ended the postive side of the pump to a water Trap then route to carbs maybe, The vac gens seem to produce quicker volumes of gas per min.
The AMP draw is would be the next hurdle to jump imho. But not impossibe to beat.
Rotax 2 stroke engines for Ultra-Light Aircraft used Bing carbs, Theres a fuel primer barb thats threaded just perfect for injecting direct into the carb throat. It would require drill and tap of the carb bodys, But not a big deal.
I think I would want head temp gauges on ea bank and exhaust gas temps as well to monitor how lean/rich and run the stock engine with these first to get a good set of working numbers to work from.
I would only want the gen turned on during throtte not while idling, use of switches, relays and shut off solnolds.
Less chance of build up in cowling
See what you did to me, another project to dwell on. Thanks keep us posted how its going. Steve
