Old 07-31-2008, 09:26 PM
Default Re: Quick Question: 23' SF Inboard
Yes, it's normal. Ball scuppers will not work with the thru-hull deck drains. But yes, you can put a standard 1" rubber drain plug in the hole from the deck side. If you have the spray deflectors on the hull, you can even put the plugs in from the outside.
Fr. Frank says:
Currently without a SeaCraft
