Old 08-11-2008, 10:29 PM
BigLew BigLew is offline
Default Re: gelcoat not for me
Thanks lew I put that in the archive of stuff to know. i like the idae of using the plastic and 5200 so hold the tank in.
I think you might want to re-read that part. I believe the article said to 5200 the plastic/phenolic like strips to the tank and set the whole tank/strips down on the (in this case fiberglass encapsulated shelf) base with NO straps, foam or anything that will hold moisture against the aluminum. The weight of the tank will hold it in place and the surrounding bulkheads (stringers, etc.) will restrict any significant movement movement. That's what I remember reading, but I would re-read it before I finalized my plan.
Good luck.
Plan accordingly!
