Old 09-04-2008, 03:59 PM
scrapper scrapper is offline
Default Re: t-top on a center console
The ones that I've worked on you can't get your hand in between the deck and the stringer. Even if you drill a hole you can't get your hand in there to put the hardware on. I guess you could drill two holes on each side, close to the legs, that many work but then you have four holes in your deck. Best bet is a winter time project of removing the top and fixing the holes the right way. Your in Court House.. is this your boat..?
not my boat.i've seen that boat for sale for a long time.my top is similar to that top.the screws are loose in the forward legs.i would like to thru bolt them.i called the guy who owns that boat you posted,he has a repair shop,he quoted me a price for a new deck-i don't need a new deck,it's fine.the screws vibrated loose,the top working up and down caused the screws to chew up the deck a little-the reason the screws are loose.
i didn't know if there was a bulkhead or something else under the deck,i asked if i could cut deck plates there,i thought someone on here would know.
