Old 09-07-2008, 07:02 PM
Default Re: Gas Tank Hatch ?
A hatch would look cleaner than the screws, caulk and pie plates.
If you seal the panel, lay a line of mono filament line down before you caulk it, that way if you need to remove the panel, pull the mono up to cut the caulk which makes removing the panel easy.
Both thoughts are good. In reality the boat will most likely out last me. So maybe the best way is two small hatches and not worry about tank removal.
Any more thoughts out there?
