Old 10-01-2008, 11:18 PM
Tarpun Tarpun is offline
Default Re: Need ideas to stop porpoising?
My fuel filter is mounted on the transom inside of the access door beneath the starbord side stern cooler/baitbox. The fuel transducer mounts next to it. On my application I just fed the cable under the deck back to the console. The transducer cable is the only wire that needs to leave the console and it's about the size of maybe #10 wire. You could bundle it with your motor harness or at least feed it thru the same access.
Tarpun
1972 20 Seafari
1977 23 Savage
1980 20'Master Angler
