I broke the bolt that connects the hyd. steering to the motor steering arm.It sounded like it was in a bind when I tilted the engine up,there was a loud pop. Should both sides of the mounting brackets move freely or is one of them mounted firmly.See pics.I had to take the brackets off to get to the broken off bolt.Any suggestions as to how to remove the broken off bolt.I removed the hyd. assembly so that I might be able to drill it out. The bracket you see still attached will not freely rotate. [image]
[/image] [image]
[/image] [image]
[/image]
