Re: hyd. steering help
I just managed to break loose the arm , you were right it took lots and lots of extreme heat. I'm going to use some crocus cloth to polish up the shaft before i remount the arm.What should I grease the shaft with before mounting . After this lesson learned I will grease/lubricate this joint periodically from now on.
