Old 11-12-2008, 06:04 PM
Tiny Tiny is offline
Default Flo-Scan dual scan for sale
Used less than 10 hours. Its a complete unit with a sender for each engine (twins) with about a 20 ft run of wire to each sender. Boat burned so much gas we sold it. Paid $485.
First $350 takes it, plus shipping.
A flo-scan WILL save you a lot of money. We've had several boats and once we installed a fuel monitering system we cut our fuel burn by at least 30% in each case.
Part number 3FB012U1 231-2 A quick call to them and they can tell you if it fits your application. (206) 524-6625
More details below.
Matt
North Palm Beach, Fl (pickup is fine)
561-358-4079
http://www.floscan.com/html/blue/ser...sid=14&catid=2
TwinScan™ Instruments embody a new concept in twin engine analog instrumentation which sets the ultimate standard for easy readability in the least possible space. Each individual instrument contains port and starboard meters which reference to each other. TwinScan instruments reduce the panel space required by 50% leaving more room for other electronics. TwinScan Fuel Flowmeters and Tachometers are sold separately.
Features
GPH models is 0-24 gallons per engine. Color styles include black dial/bezel.
Microprocessor electronics for high performance features like electronic dampening, linear dial scales, superior accuracy unaffected by ground voltage shifts.
Patented, magnetically shielded, precision, miniature air-core meter movement with state-of-the-art engineering features.
Corrosion free stainless steel bezel and molded acetal cases which fit standard 3-3/8" diameter holes.
Reverse polarity and load dump protection exceeding SAE J1810 standards.
Dial faces: Red on Black. U.S Scale.
