Old 11-17-2008, 09:52 AM
Default Re: Classic 1963 21 Video and pics
Blown spider gears at the least. Blown main shaft in the lower unit or worse! We used to blow 2 or 3 shear pins a summer in an old Rude 40 pull start on a little Whaler in Barnstable harbor as a child. One of the things I like about the mirage + is you can change the hub out in a jiffy if you dont drop anything in the water.... If you do spin a rubber hub, you can usually back off the pin and limp in.
Ron White called. How many Koopens for a ride at Long Point?
Sluggo wants a ride too.
The Merc prop selector on the site is pretty good for a starting point.
GFS
Looks like the chines are flying!
