Re: Seafari Questions/photos
Denny, thanks for info..I feared that I got a lemon due to the missing stringer on port side...you are correct, the inboard stringer stops short and there is foam up in there and in between the outboard and inboard stringer up to the point where the inboard stringer stops (just forward of the rear cockpit wall (i guess you can call it that??)...the foam is covered in grey paint of some type?? Appears to be original because I can see where someone before tried to paint and could only go up so far due to the port storage bin being fixed in place. I will go to a sign shop down the road and see if they can somewhat produce my decal. I will share info regarding decal if they can in fact duplicate it might be interesting for other SC owners as well.
Father Frank..interesting about the twin 85 setup..what a squeeze it must have been even with a wide transom setup.
Thanks again
-Fred
