Old 12-09-2008, 10:37 PM
Rob40 Rob40 is offline
Default Re: 20 seafari 1977 w/Honda 130hp & alum trlr $8800
I used to work in aircraft composites, so I had some "leftovers" to do my transom repair. Most of the adhesive/resin used was epoxy,I did have to use poly resin for some of the inside areas.The transom was cut out on the inside , used marine plywood with mat in between saturated in epoxy, drilled small holes in trans to temp screw the wood to outter skin. Built a battery box/ fuel filter area on the r/h side, the l/h side is a little well with drain. The bench seat is only for storage underneath. This boat was stored at a marina boathouse indoors from '78 - 2000 I'm guessing.The original owner died and his widow sold it to me 5 years later. There was a stack of Alabama Deep Sea fishing Rodeo programs in the cuddy, I guess they fished the rodeo alot. (pretty cool)It came with the 4cyl volvo penta, tried to revive it but... with the all the rust on it it had to go.
