Old 01-10-2009, 01:03 PM
striker striker is offline
Default Re: 1975 SeaCraft CC , 18' ..Transom height change ??
thanks Groveguy ... so if I am understanding correctly , a 25" transom " does not " require a 30" shaft motor to keep the gear pod and prop at the correct depth in the water .
In other words , a 25" transom height requires a 25" shaft motor as standard proceedure ??
Nephew is thinking because he has a 20" transom as it exist now , that a 25" shaft motor would be "required" to get the pod and prop below the keel and in the correct position .
I am just trying to be sure about this before I raise his transom height 5" more . I should know the answer to my own question by now , but the Nephew has given me reason to doubt my understanding .
