Old 01-10-2009, 09:54 PM
Default Re: 1975 SeaCraft CC , 18' ..Transom height change ??
30" motors are now available, although not as common as 25" versions, so probably quite a bit more expensive, and probably only available on the larger motors. Probably not needed for an 18 as long as you stay with a fairly light 300-350 lb 2-stroke motor. The transom cutout would be 30" above the keel if you decided to go that route. Although Skip & Carla are planning to mount twin 25" motors on their ex-raceboat 21, Skip also set the transom cutout up for a single 30" motor in case someone in future wanted to convert it to a big single, but that's a MUCH bigger boat than an 18!
