Re: Trim/Tilt Pump on 225 Mercury
Danny, If you have a clicking sound chances are its the solenoid. I would definitely check your battery connections and make sure they are absolutely clean. If you have 2 batts use some jumpers and see if 24 volts cures your ills. I can get you parts for cheep. My 19999 60hp Suzuki clicks while trying to raise the motor if the battery is discharged partially. Also since you have twins you can switch the solonoids.
Capt. Brian
