Waterpump would initially only register pressure in the water and not on the earmuffs, it is a new lower unit.
I have the same motor and it WONT run on muffs. I have to run it in a barrel in the yard. On muffs it CAN NOT seem to get enough water and will heat up. Mine has new water pump/t stats/ popit and is in good working order. In the water its as happy as a clam.
What prop are you running and what kind of #'s (cruise/top end) can you share with us?
