Old 01-28-2009, 08:53 PM
Default Re: VHF Antenna lengths
Hey John,
You might want to check out an 8' Digital.
A couple pro's with them is;
- Order the antenna cable in custom length(but believe no shorter than 4') for neater install as i recall potential issues based upon how you wind up the excess cable. Others may recall, use figure "8" versus circle?
- The soldered end(factory installed and tested, nice ) of antenna cable is the approx same size of the cable(the larger radio connections screw on after routing), so easier to fit thru tight chases and simple mechanical conection to radio.
Cons were don't wait for the spring to custom order, you may not see it for a few weeks ...
- Nick
