Thread: I have a leak
Old 02-22-2009, 06:10 PM
Default Re: I have a leak
AAAHHHH HAAAAA - I found it- can't tempt the keys crazy chit happens there as its in the Bermuda Triangle - so it turns out its the drain tube for the baitwell much better than the scupper. Checked the Bildge pumps both working and the auto switch as well, was worried leaving it in the water.
A quick isolate and eliminate check list - plug the baitwell from the outside - fill, empty's somewhat quickly into bildge - still could be a leak on the inside of the baitwell as there are some cracks that had sealer on them, that I resealed - meaning this isn't new to the boat.
Dry and place Duct tape over inside of the drain and the fill nozzle that I can see in the bildge and wasn't leaking but did it anyway - every orfice.
Water held just fine no problems - pulled tape from fill - no water, as expected - plugged the outside of the drain and placed bucket to measure any drips and pulled the tape off the drain on the inside - RAN SLAP INTO THE BILDGE AS SOON AS WATER GOT INTO THAT TUBE - ISOLATE AND ELIMINATE IS YOUR FRIEND.
OK I mis-spelled bilge 5 times and I'm not fixing it - screw off before you even say it
