Old 03-02-2009, 10:28 PM
Default Re: 30 year old fuel tank
Pretty sure the CG will NOT due a test, either a tank manufacturer or yourself will have to do it, not to many other people will take on the liability on a used tank, as far as coatings go, stick to one manufacturer, IE, Interlux, Pettit, etc. Haven't heard of coal tar being used in eons. Might want to reasearch that a little further. I do know if you are coating old aluminum you better make sure it is clean, and a wire brush isn't going to cut it, it should involve some kind of etching acid of the same manufactures of the epoxy you plan to use.
1972 20' SeaCraft SF, F200XB
1974 40' Eagle
www.parkeryacht.com
