Re: fuel tank
Personally I would put a lower unit pressure pump on there, pump up to about 3 or 4 lbs, check the bleed down, but everything needs to be capped, or at least with hoses,plugs and hose clamps. I'm not so sure about the way it is done in the pictures, I would double check, save yourself some $$$$.
