Re: water flow
The outdrive pump has nothing to do with engine cooling on a fresh water cooled closed system. The raw water pump takes care of the engine. The outdrive pump should be retained as it helps cool the outdrive and the hose at the top of the outdrive is cut and just squirts the water out. I have the same set up on my Sceptre w/260 Mercruiser and it works fine.
