Old 04-06-2009, 10:55 AM
Rainmaker Rainmaker is offline
Default Re: new transom or enclose w/bracket?
When you install a bracket you can raise the motor significantly. The bracket design can be matched to your application. I would think you will be fine.
I added a bracket to my 23 because I had a new motor that I wanted to use and it was a 25" shaft while the transom was set for a 30". All is well and the boat rides great with the bracket and motor.
