Old 04-06-2009, 09:50 PM
BigLew BigLew is offline
Default Re: installing motor mount bolts?
It is a PITA, but your best bet is too over drill a hole. Then refill the hole with epoxy or epoxy and cabosil creating a plug. Then drill these plugs to the correct size as you would if you had not made the plug. This way, the transom core never comes in contact with any water.
Plan accordingly!
