Re: Transom problems
You are delaying the enevitable, bondo will do you absolutly no good, other than to cover a bigger problem. You could remove as much as the rotted wood as you can, dry out, and fill with Sea Cast or another type of epoxy, this will do nothing for the areas you can't see or access, that area will continue to crack, eventually you will need to replace the transom. good luck.
